01.11.2010, 03:03 PM
2. I'd figure thats how quickly the throttle reacts from neutral- soft acceleration woudl be ideal if you can manage to get it programmed & saved.
3. One mans soft is anothers hard- you may be able to dial it down somewhat with epa, but it is a plane/boat esc after all- no proportional or gradual braking effect..
4. Your anaolgy is correct, and highly ammusing. Soft cutoff will probably cause the throttle to either reduce power before eventually cutting out fully, or maybe pulse the throttle before..
5. Yeah, most BL inrunners are 2 pole (feigao, lehner,) or 4 pole (neu, medusa, castleneu). If you turned up the timing then it would cause much greater current draw for precious little improvement in power, resulting in melted electronics eventually.
6. Thats something PDelCast talked about a while back- different motors have different ideal drive frequencies, but without knowing what they are specifically it can have an adverse effect on either the motor or the esc ( motor might like a higher frequency, but it means the esc has to work harder, and viceversa ). Best left as it is really yeah.
Cant really help with the actual programming routine- using the tx to select all the options & settings would be my idea of hell....
