Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.13.2010, 09:27 AM
Nice use of the diamond plate and all of the CF . You set up should be fairly light. Curious as to why the 8 shocks and not the muggy/LST..is it weight savings you are after or a performance advantage
IF and when I go to the 8ight shocks I will only be using 4, not 8.
And FYI, I did order a set of plastic shock bodys to compare weight and possibley reconsider running them instead. Under $8.00 for 4 NIP, might as well since they will not go bad sitting in the bag ?
