skellyo
skellyo's Avatar
01.15.2010, 03:28 PM
OK, got the motor in yesterday, installed it, and it runs fine. However, none of the 32p 1/8" bore pinions I have fit onto the VXL shaft, but they fit fine on the CC motor. Is this normal for the VXL motor? I believe the pinions I have are RobinsonRacing (from my LHS).
If you have some, try a bit of 320 or 500 grit sandpaper on the motor shaft. There may be just a tiny sticking point on either shaft or pinion bore. I've had to do that with a couple of CC motors before.
