Big ass brushless savage
4xFord
Big ass brushless savage - 01.16.2010, 04:09 AM
Well, the thread title pretty much sums it up. Here are some pics to get the build started.
It has an 18" WB chassis. I am gonna run a Tekin T8 1700kv motor that I have here, probably off my MMM. However if I run across the Tekin esc I will try that since for the sensor.
I am going to run it off 4s to start. If I think I need more I will go to 5s, however this is just a basher and I just need enough speed to get it off the ramps.
Here are some battery location pics. This is two 4s 20c 4000mah packs that will be run together at 4s 40c 8000mah. Should have great run time.
I also have two of these packs, these would be run one at a time. Specs in the pic.
The packs are low in the chassis. I have a flux mount here and custom clamps on order. Should be a fun truck. Now I just need an 18" WB body, any suggestions?
Also, I have some 40 series BL's with mashers, and I also have some CEN wheels/tires on the way. Not sure which ones will end up on her, probably the lighter of the two.
Oh ya and I have some savage bulks with CEN arms, hubs, and cvd's on the way to give a shot. They have the HPI bulletproofs in them. And I also have some HPI bulletproofs for these if I decide to stick with the stock setup.
Oh, and if anyone could be so kind as to help me with part numbers and or links to the parts needed to fix this trans up to flux single speed specs I would be forever grateful.
