Overdriven
Destroyer of Tires
Overdriven's Avatar
01.16.2010, 11:34 PM
I plan to use regular knuckles, and weld "c hubs" to the axle tubes. The cvds would be assembled to the knuckles with the cen 23mm hexes and then the whole deal slid into the tube and attached to the c hub. This will require that the knuckles be removed to allow the diff to come out, but it will be 2 wheel nuts and 8 screws max to get the diff out.
I really want a 1 piece axle. My design should be stronger than any sort of split axle, despite having notches for the diff to slide in. Mainly looking to make 1 wheel landings repeatable...
Oh, duh. Don't know why I was thinking your axle tube would be notched the whole length for the cvd. I need some sleep, the days are blending together. Can't wait to see a finished axle though. I've been wanting to do something similar for a while too.
