Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
01.18.2010, 10:04 PM
That's cool, I was just trying to help.
You might want to try a stiffer spring, like Purple, since you have the pre-load cranked way down. Like I said, a longer spring of the same weight does absolutely nothing different than the shorter spring of the same weight except stop you from cranking the pre-load so far down.
Pre-load is ONLY for adjusting ride-height, it does not make the springs/suspension stiffer, you need a stiffer spring for that.
-Chad
PM ME IF YOU HAVE THE BELOW:
