mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
01.20.2010, 12:23 AM
Originally Posted by phatmonk View Post
Hey guys will the Summit driveshafts fit my E Revo.They share the same suspention arms.
The Summit shafts are sold complete on ebay only. They are generally sold in pairs of a short one and a long one. You need the long one only. The prices went up as I can see. They are less prone to twisting or snapping but the components wear out quickly and get very sloppy in a short while. I have said it before and will say it again, no matter what shafts you use, they will last much longer if you have a good slipper that is set up right and can take some abuse. Get the aluminum slipper pads from Traxxas when they come out. Aluminum pads will take serious slipping abuse and will not burn out like the stock ones so the slipper can be set much looser which is beneficial to all the drive train's components.
No brain, no headaches.
