Thread: Castle 1717
Unsullied_Spy
Unsullied_Spy's Avatar
01.21.2010, 01:57 AM
Originally Posted by riverat1540 View Post
wow you were that heavy? with the roll cage i am only at 13lbs with the medusa 80mm. just got the losi hardened chassis and it is much stiffer than stock, need to order a motor mount and a battery tray from mike as i just sold them with the Jammin CRT, cant wait to try the 1520 when i have the money. as the medusa gets a little heated after hard running
Yeah, it weighed a ton. Doesn't help when you have massive tires with foams that are soaked Also, my battery setups were very heavy (6s 5000 mAH was the lightest setup I ran and it weighed over a KG).
