MetalMan
MetalMan's Avatar
02.05.2006, 08:13 PM
ygguB naM, I am tcolesen over on RCZ (just letting you know). Your case with Maxamps doesn't prove much, to be honest.
Superemaxx89, here is a link to a LVC device you can use:
http://www.dimensionengineering.com/LipoShield.htm You only need one of these, but it will need to be hooked up to the total voltage from both 3s packs (you could hook it up to the input wires on the controller).
To be honest with you, I think you are spending way too much money on batteries. If you have a mishap, that could mean $250+ gone. What I would suggest is getting 4 3s 4000mah packs, and only using 2 at a time (in series). The 4000mah cells can handle the amp draw just fine in 1p, and when they run down you could just switch them with the other 2 packs. Overall, I think this would be the best setup if you are still looking to spend a lot of money.
