MetalMan
MetalMan's Avatar
02.05.2006, 08:46 PM
Maxamps has very good customer service, undoubtedly one of the best out there.
If you're going to be using the Hyperion LBA6 balancer, then you can get the Hyperion balancing taps.
As far as 48amps goes, that is the continuous rating. Your truck will only require ~23amps average, but will pull more in bursts. These cells are rated at 64amps burst for 10 sec., and can handle even more in shorter bursts (spikes). In 1p they will be plenty, especially since you're using a pretty high voltage setup.
