NickRummy
NickRummy's Avatar
01.24.2010, 10:37 PM
Not the progress I was hoping to make but having a 3 month old at home will do that I suppose
Radius arm brackets and beam brackets are brazed on. Changed the caster on the beams so they're sitting correctly. Was hoping to get the shock mounts done but that's going to take some more work. I need to swap around the links that adjust the axle C's caster so that I have room for the shock to mount to the beam. The shocks can mount up now but I can't lean them back for the proper angle. Going to pack it all up tomorrow and take it into work to try and get the shock mounts bent up.
Here's the full stuff now. I could get more if I change around some clearance on the beams. The beam mount contacts it and keeps it from being able to go all the way up to the frame.
Won't know how much actual drop out it has until the shocks are mounted up but it's capable of a lot!
