Thread: Tire choices?
_dV
01.25.2010, 09:08 AM
The wheels are balanced, although it's with blutac atm. Suprisingly it hasn't come off once. Certainly makes the truck run smoother at speed.
If i remember the largest blutac chunk was 11gm and the smallest was 6gm. The 11 gm one is reasonably large and you can see it easily through the wheel but once it gets dirty you don't even notice it all while driving.
I was trying to devise a way to double sided tape a plastic cable holder to the inside of the wheel and then put various small lead sinker weights inside it. Just seemed too dangerous though even if i glued them in so i have just stuck with the blutac.
