brushlessboy16
brushlessboy16's Avatar
01.26.2010, 01:04 PM
Unless I am reading the specs wrong it appears that the drive sprokets use a 1/8 square drive... Hopefully they can be modded to handle something a bit stronger.
Read the instruction manual for those treads. They are designed to use fixed bogies, and I am not sure what kind of load they will handle as they are just "snapped" together. I would like to see some sort of rubber coated steel setup with individual pivot pins that are held in with e clips or some thing like that... Overbuilt...
Thus comes the extra cost.. I have the standard boogies on home made suspension arms to cut down on cost..
