Originally Posted by skellyo
So let me get this straight...you're running a 2650kv on 6S and gearing it for ~120mph?
I'm quite surprised you haven't melted your motor several times over already. A ~6:1 FDR in a 1/8th buggy is going to put stupid amounts of load on the motor.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 2650
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.0035
Spur/Pinion Ratio: 1.84 : 1
Total Ratio: 6.08615 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Rollout: 2.22:1
Total Motor Speed: 58830 RPM
Vehicle Speed: 123.65 mph (198.63 km/h)
Effective KV Value: 2650
KT constant: 0.51 oz-in/A
actually, you're not far off. most of us have already gotten over 95mph and a few of us have broken 100mph when it was a bit warmer with the grp rally tires.
Originally Posted by snellemin
hmmm, the next thing will be making a custom hub for the solid diff option(OFN33020), so you can run smaller traxxas spurs. This is what I'm going to do with my GTP.
excellent idea. i'll look into that. thanks a bunch!
