JThiessen
JThiessen's Avatar
01.26.2010, 02:23 PM
Originally Posted by Doug Shelp View Post
little help,im running a X1CRT,novakHV,6.5,5000 35c 2sX2,
Are you running two packs? Most of the people that have had this issue were set up with one pack.
Try switching out your servo for a lower power one - high power servos have been know to temporarily kill the HV systems. The other potential is that its your LVC prematurely kicking in - another known HV problem. I went around the block on this same issue - only resolution that worked in my situation was a change in mfgr.
