Originally Posted by Gustav
Just based on experience.i only managed to get 40mph out of my LST with my 11 port sirio .27 which is a peachy motor.Is it a big block in your revo?if so i can see how you get 50mph but if it's a small block then that's impressive.i can't be bothered with nitro at the moment,you can't use a starter box with the LST and pull starts do my nut.
Gustav and Boss. the reason the revo can be capable of close to 50 is because of different climates, different tuning (maybe), and the fact that the 2.5 is capable of near 50,000 RPM redline. Plus the revo itself is very light compared to other trucks, which means the power to weight ratio is higher than other trucks.
