Modding_out
disturb'in the peace......
Modding_out's Avatar
01.29.2010, 12:07 AM
This is how, I see it.
The 3rrod is a cooling issue(for the most part) And this console was never allowed to or played long enough at any given time to over heat. Also since my 3rrod seamed to be more of a glitch,(and first time ever) than the more permanent kind of 3rrod I'm going to fix the problem before it starts.
t-maxxracer32 If I run into any problems doing the x-clamp (delete) mod, I'll give you a call. But on the other hand did you ever think that maybe letting the 360's go like that might be causing the dependability problems after the fact?
Also, in conjunction with x- clamp removal(gonna bolt the chip set strait to the mother board) I'm gonna remove some of the internal baffles in the grates to allow more air in. How does that sound guys?
