sikeston34m
sikeston34m's Avatar
01.29.2010, 12:41 PM
Originally Posted by aqwut View Post
Sure it would...! ... if it's cogging at the start, then it's geared too high..
I would do a little bit higher RPMs though.. that's a tad bit low..
if running wanting to use 4S, I would do the 1700KV...
My opinion, Gear it high with the 1000KV KB-45XL...
I just acquired a couple of 25 tooth Mod 1 gears with the 6mm ID.
This NEW KB45 10 XL had just been sitting around waiting for some action.
Here is my proposed setup now:
E Revo
MMM
Apogee Limn 3800mah 6S or 6S Turnigy 5000mah
KB45 10XL geared 25/40 using Mod 1 gears
Now the only thing I'm missing is those m4 screws to mount the motor with.
Where can I find those pesky things?
How well will this setup work?
