sikeston34m
sikeston34m's Avatar
01.31.2010, 05:46 PM
Originally Posted by tashpop View Post
i have the 1200kv xl sitting in a box now awaiting a nice heavy project one day.
Hi Tash. What are you calling a "heavy project"?
The 6mm id motor pinion I'm using is stainless. Are they any good?
It snowed here before I got a chance to really test this out.
Just a few short bursts on my cleaned off drive, shows a little cogging at startup/crawling speeds. But WOT results in a quick spin around. It was kinda wet out.
I'm thinking about replacing the 40 tooth spur with a 46 tooth version.
25/40 changed to 25/46
Short tests were done on 5S. In about 10 minutes, the motor got up to around 130 degrees.
