02.06.2006, 05:25 PM
usually the rule of thumb is up to double the mah of the battery ( for eg - 3600 cells - is 3.6 + 3.6 = 7.4 volts - we charge them at 6.0 amps though - so i would say 6.0 amps is good - also charging at a higher rate will give more "punch" as opposed to lower charge rates giving slightly more run time and more smooth power initially - thats what i have experienced - not that noticable though -
Hows that "Hope and Change" working out for Ya???
