Pentagon
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
Pentagon - 02.01.2010, 06:38 PM
First of all, WHERE IS THE HOLE TO FIT A 757 INTO?!? That alone is enough to sound the "BULLSHIT ALARM".
Where is all the fire damage from all the fuel onboard? You saw the huge fireball on the twin towers (of which most of the fuel would have been burned off in the immediate explosion), but here you can clearly see open offices with the walls blown off with books and stools seemingly undamaged by the fire (or lack there of)??
Why does the plane have no wings? Aren't 757's principle of flight from the fundamental effect of air flow of an air foil wing? So where are the craters in the Pentagon where the wings should have been? Did they fall of before hand? Did they break off when hitting the building? If so, where are they then?
Why are is there hole roughly 7 feet diameter that goes through not one, not two, but THREE rings on the pentagon! So how can the fuselage do that kind of damage (made of aluminum...), and the wings (which would weight a large portion of the total mass of the plane) not do ANYTHING to the front of the building, not even to glass windows!! The only thing that could possibly do that would be maybe a small military drone aircraft (UAV?), or a bunker buster missile.
The engine is way too small to be from a 757 jet liner, but does line up with the size of engine used in the Global Hawk UAV. The wheels left in the debris also are a match for design and size to a UAV as well. Not saying it was a UAV though... we have no definite evidence of what it was, but it wasn't a 757!
Human remains... hgmm... I mean no human remains, nothing... how can you have no human remains and have pieces of fuselage on the lawn of the Pentagon with seemingly "American Airlines" letters and colors, that aren't even burnt? Ya, that adds up!
Check out the pictures.
ID:	8425   Click image for larger version
ID:	8426   Click image for larger version
