thzero
02.02.2010, 12:32 AM
Well, if its within 2 or 3 lbs, thats not too bad. However I think the TCS Crawler stuff is unnecessarily heavy. 4mm probably would have sufficed; maybe even 3.5mm.
And everyone seems to think the 5t sized savvy will be sooo close to a regular savage weight... You got an extra pound in tvps... Depending on tire and body choice you could easily be looking at 3+ lbs. Lower gearing and good lipos will be a must for the flux setup, and forget 4s...
