Krawlin
Got brushless?
Krawlin's Avatar
02.03.2010, 12:55 AM
PICTURES!!!!
I got the conversion completely finished and drove it around my yard a bit. It's under-geared by a tooth or two on the pinion, but it was pretty fast considering it was under-geared, then again it could be the size of this truck that makes it seem like its moving alot faster than it is (sort of like running a 1/5, but not quite that big). It sure does handle like an MT though, , definitely needs some toe and camber adjustments, its a bit out of whack in that area, and maybe a sway bar addition somewhere down the line.
Anyway, here are the pics......
Also, I ordered Proline 23mm hex 1/2 offset MT dish wheels and Proline Badlands tires. The truck should look alot better with some 1/2 offset MT wheels, will give it a much wider stance than those 40 series do.
Monster GT Conversion
