Thread: 3906 diff
chrismechanic
02.03.2010, 05:59 AM
hi all...thanks for the advise guys, neil stop lying, overseas is good enough??
i just bought a fastlane ally g/box case for me e-maxx and ohh dear,
only two of the motor plate screws will go in (other hole is out of line),
the motor plate locators are undersize so the motorplate is very loose against the case. and the flat mount surface for the gearbox isnt flat, one side has a higher flat on.
so ive just paid nearly £100.00 for a peice of scrap alloy.
really its pathetic, i could get a better fit with a chainsaw.
its taken 2 months of e-mails and still no replacement case??
this case was made on a cnc machine capable of working to around 0.005mm tolerance and the locators are undersize by .40mm, that tells me the person who set up the job really screwed it up badly. whats the point of a £60.000 machine if the operator can't use it? might as well use a file/chainsaw/fire axe.
got me off one one again
see ya all...
