enlighten
02.03.2010, 06:56 PM
Originally Posted by Nard Cox View Post
Awesome build!! I have some Q's:
You have a picture of that white card set-up?
Which mudguards are that? I also want some for my STe!
Where are you going to put the MMP?
What dimensions does that tray have and would it fit a regular STe chassis?
Thanks Nard, Snellemin & Mas!
Pic attached of the photo setup. I always use a tripod too but also works well with flash. Find a place with good window light, set white balance to 'cloudy', select a small apeture (for good depth of field), and use a 2 second self timer.
Photography's another hobby of mine and the technical aspect is surprisingly simple once you get into it. Takes about 5 mins to setup.
Mudgaurds are Tekno RC's. Available from their store...
http://www.impaktrc.com/product_info...oducts_id=2868
or Nitrohouse have them too. Found them from people fitting them to their Hyper 9e's. Check how much your servo extends on the STe, don't know if it might hit the gaurd. worth a go I reckon.
The MMP will go on the plate behind the receiver box, between the battery and motor. Bit high COG but whatever. They've done a great job with wiring with the new parts. Particularly, the servo wire is kept away from the spur nicely and the ESC wire will go directly into the back of the receiver box. It'll only be battery and motor wires exposed.
I'm stumped at whether the tray will fit an STe??? Got me there!
I'm lovin the Tekno too. 'mmmmm... My precious'
I got it from impact rc when they had em on sale for $99
And MAS the total retail cost for parts was US$50 (think it cost $42 or something). You can see the parts and prices on them in the first pic of the thread. I had slowly accumulated the rest already for my CRT.5... and yes that was expensive when it all adds up!
Check out special-rc on ebay for parts as well. He doesn't have them listed but he can get them from Hong Nor. Cheaper than Nitrohouse too (except he had the motor mount at $35 for some reason?? May have been a mistake???)
Cheers!
Name:	aaa photo card.jpg
