02.04.2010, 01:26 AM
The minimum input voltage on that BEC is listed as 6V. I thought it would behave the same or worse than the CC BEC once the voltage drops below 5-6V? I see you run 2s LiFe in your GenX-10, do you use this Park BEC with that and have no issues?
