SpeedAssault
SpeedAssault's Avatar
02.05.2010, 07:16 PM
Originally Posted by squeeforever View Post
Definitely go with the Summit shafts they should hold up for sure.
?You have some experience with them ?
Pricey SUCKERS !
$10. x4 for stubs
$10. X 4 for outputs
$8. x 2 for shafts
$96.
http://www.traxxas.com/support/kb_se...cat=143&id=620
Or I could go with Losi after shock Shafts and then find 4 large OD Bearing with small 8mm ID to use in the revo knuckle and buy 4 8mm outside bearings
cheaper route and I get shiney metal axle that are CV's
