Kcaz25
Kcaz25's Avatar
02.08.2010, 08:40 AM
Thanks guys! Chad you should not only recognize your wing parts but the chassis as well as it is a trimmed HCR Mutant (so its titanium of course) without a top plate sold to me by user 3.3maxx if you look hard you can see the top plate in the back ground. I ditched the top plate for several reasons, the three main reasons are as follows, some of the posts were striped, I really wanted to lay the servo down like a losi truggy and, it really gets in the way when trying to do an electric conversion.
I'm wanting to give it some kick-up as the mutant uses all rear bulks and has no kick-up. I'm thinking I'll put some shims under the bulks to give some suspension kick-up, but that'll still leave the chassis without any kick-up. What do you guys think about bending the chassis alittle and using a front bulk anyway?
Lito after talking with you in another thread you seem to think that the plastic rod ends are a bad idea and that I should use metal. Can you link me to the correct size, I'm going to be using TRX Red Tube turnbuckles and was planning on using Dubro Monster ball links which are much bigger than what you see in the picture above.
Thanks,
Zack
