crazyjr
crazyjr's Avatar
02.07.2006, 11:36 PM
Got to run my G2R again today. it has rained almost every other day here and i never run any r/c's for two days after it rains, just to be safe.
I made some changes to the setup and they proved good.
First i moved the rear shocks to the front and used the silver front springs with 40wt shock oil and set the threaded shock mount to just tensioning the spring with no pressure.
For the rear i took the front shocks and replaced the piston with the extra piston(#3)and filled with 40wt oil and blue spring set to just tension the spring without pressure.
no changes other than described and the truck is in better control and smoother in the bumps.
