Originally Posted by rawfuls
I believe one of the articles I read suggests that all plugs are backwards compatible, but not forward, which means if the one you have is the newer one, (the plug), it SHOULD be able to go into the (older) console, however if you have a plug that CANT go into a system, usually means that you'll need a new plug (and that the newer console) is newer than the one you had previously.
I think the article was in this thread, or in modding_out's thread.
well if thats the case, you can cut a slot in the old cord to fit the new plug
