UE Supermaxx Addict!
02.08.2010, 09:33 PM
I actually have a Mutant-Maxx chassis that has been bent to have kick-up and use front bulkheads in the front, and it works great! You can't use the top-plate anymore after you bend in the kick-up, but you aren't using it anyway, so no problem there.
I like how you chopped off the rear section in order to mount the UE Mono-Block, that's cool!
Also, the JT chassis uses standard bulkheads, not VBS...only the UE VBS version uses VBS.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
