Kcaz25
Kcaz25's Avatar
02.08.2010, 09:53 PM
Originally Posted by Chadworkz View Post
I actually have a Mutant-Maxx chassis that has been bent to have kick-up and use front bulkheads in the front, and it works great! You can't use the top-plate anymore after you bend in the kick-up, but you aren't using it anyway, so no problem there.
I like how you chopped off the rear section in order to mount the UE Mono-Block, that's cool!
Also, the JT chassis uses standard bulkheads, not VBS...only the UE VBS version uses VBS.
I saw the better pictures you have and came to think maybe the chassis does have kick-up prior to buying this one. But it doesn't. Did you bend it? If so can you give me tips about it. I don't want to mess it up. I know even titanium doesn't like being bent but the bulkhead will probably give a backbone in that spot.
Anyway, I actually haven't cut the chassis. HEHE
Thanks for the VBS confirmation.
