02.08.2010, 11:41 PM
Brian your running the original CRT.5 chassis? I got the OFNA extended chassis just so I could use a full size servo (Hitec 645MG). I have also used a Spektrum Z590 servo, just put the hitec in there because it is a better servo and I had it, both threw the tires around with ease. The extended chassis isn't much bigger, just enough to use a real servo.
