Originally Posted by Unsullied_Spy
VERY good to hear! Are they going to be regular cooling plates or some kind of water block like you find in a water cooled computer? As long as you can keep the resistace low enough the water block would offer superior cooling capacity. At any rate, I've got 3 boats right now...and only 1 good ESC
We took the heat sink fins off the cooling extrusion, and replaced them with channels for cooling tubes. The cooling extrusion bonds to the bus bars and the FET packages -- it is very effective at cooling the circuit board.
