pinkpanda3310
pinkpanda3310's Avatar
02.11.2010, 09:05 PM
Were you getting some shafts to fit your new cd mount? What size do you need? I don't make them but I've had a quick look at what other cars use as stock. LST1 axle cvd's are about 145mm, mammoth front centre swing shaft's are 182mm off the top of my head.
If you don't mind dealing with Dan @ kershaws, he can also help with stock shaft lengths. If not then I would just ask Mike for a custom.
