Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.12.2010, 01:57 PM
My Bash stuff; Befor every run I check steering,gear mesh and look for lose hardware/parts. Just takes a minute, Other than I run them till something breaks or causes a problem of some sort.
My Track stuff; Same as above but give everytning a solid going over the day prior to going to the track in case a issue is found and needs addressing .
Regualr maitinance ; Twice a year I go through everything on each RC, check replace bearings,worn cvd's,pins etc rebuild diffs and shocks blah blah blah.
