t-maxxracer32
t-maxxracer32's Avatar
02.13.2010, 10:14 PM
not sure if anyone mentioned this but something i did with my stampede was use a strap to hold the front of the body down so that there is only one pin in the rear. trim a hole through the body to fit the strap in and just strap it to the front skid plate. when you take the pin out the back you can fold the body up and switch out packs. If you get good enough velcro like others said then you can just velcro the pack in and it will be fine. Worst case scenario is that you try this method out and realize that this will not hold the lipos in. They are not heavy batteries and will not have alot of force trying to pull them out.
If you do not want to try the velcro on the batteries just have one good strap around them like others said and the swap should be extremely quick with only one pin on the body and do the above mod like i said.
