Slipperential into FLUX
Finnster
KillaHurtz
Finnster's Avatar
Slipperential into FLUX - 02.15.2010, 01:31 PM
IOW: If I have my #'s right, the stock FDR of the Flux is 16.1. There is no way to get to this with the bulletproof diffs and use the 46T slipperential. The other option is the 52T, and even then a v. small pinion is required.
I have a thought where this could be integrated into an FLM Flux (X or XL) TVP, where you could use a TVP crossbrace for one of the diff mounts, and just have long M4 screws coming across and mounting sideways into the motor mount side of the diff mount (or make some other part to make it fancier, but less universal.) This could then get mounted onto the FLM skid plate as well to make one full integrated unit.
I'm sure there are a good number of Savage/Flux owners who would like to get a CD into the truck. Just a couple of things need sorted out first.
It could really help differentiate the FLM TVPs for Flux versus the large number of other aftermarket TVPs for Flux also.
