Finnster
KillaHurtz
Finnster's Avatar
02.15.2010, 04:43 PM
Finn- it is intended for m3 screws, nothing a little dremeling won't take care of. It'll fit 52t spurs, but as you mentioned there would need to be spur clearance cut beneath it or it would have to be spaced up.
Everybody- stock is gone I'm glad Mike moved them and we weren't lying to him when we told him they'd sell. Viva la Monster!
Will it fit under the top brace tho? Not so worried about the bottom as it can be managed. That will be the show stopper. If Mike knows, what is the max spur size possible under the top brace?
If everything fits under, even just a set of Savage crossbraces would be all that's needed to mount this inside the TVPs.
I know its for M3, but what concerns me is the holes and recesses cut for the M3s, and may not be big enuf for M4s. At worst I suppose you have extra long M4 screws (and washers if needed) and go all the way to the inside of the mount. I had to dremmel my Kershaw Designs mount to get the M4s thru. It can be done, but its a pita and, like you, hope not not have to hack up such a nice RCM piece.
