Thread: Castle 1717
Pdelcast
Pdelcast's Avatar
02.15.2010, 10:26 PM
Originally Posted by rotary rocket View Post
Patrick,
Are you planning on releasing the 2025 at the same time as the ICE-HV-160 Car?
From the picture you posted it seems the 2025 will have a 8mm shaft. Is that the case? Can you share any additional info on the 2025?
We will probably stick with the 8mm shaft. A motor with that much torque needs a shaft that large.
Patrick del Castillo
President, Principle Engineer
