Rivermaxx
02.18.2010, 09:17 AM
I can make custom length aluminum drive shafts - will have to get a system in place here for efficiency, though.
Will aluminum be strong enough? I wonder if 7075 would work best because its harder stronger material.
I was thinking about making another Gmaxx chassis plate much like the one I made before without the tranny cutout so I can have a spot to mount the CD mount without the need for custom made shafts. I'll make a cardboard cutout once I get home from work(it's 1:00 in the afternoon here in Japan) and post some pics about this idea of mine. The aluminum plate will be 3mm thick (aircraft grade 6061T6 aluminum) and I think it will be robust enough to hold the cd in place.
I am thinking the same thing but with 3mm carbon fiber plate.
