02.18.2010, 11:46 PM
Are the wires shorted internally, or are they rubbing where they exit the motor can? If they are rubbing where they exit the can maybe you can fit a grommet in there to keep them from shorting anymore. Even a piece of balsa wood would work. It might be a temporary fix but it should make the motor usable until you can buy a replacement.
