Originally Posted by RuthlessLST
The 1717 fits without to much trouble. The hardest part is getting the gearing right.
[QUOTE=lincpimp;350883]
Originally Posted by _paralyzed_
the 1717 is way too fat for a dude mount, get a 1520 or the 1521 neu.
QUOTE]
It fits, but the 6mm shaft will cause pinion issues. Good try Harold, better luck next time. Good thing you are not the "oracle" of brushless, newbs everywhere would be screwed...
Ding, time for a cookie!
I will say the 1521 1y does great on 6s. So the 1520 cc motor should be fine. I ran a cc 2200 on 5s with truggy size tires and it did very well too. But if you plan to run bigger/heavier tires go with the 1520. 1600kv on 6s seems to be the ticket as it falls nicely with the 63/25 gearing that fits the tdr mount, and available setscrew pinions.
What gearing are you going to run with that 1717? It's hard to get good gearing because it is too fat. That's what I meant. Duhhh
