Finnster
KillaHurtz
Finnster's Avatar
02.21.2010, 01:09 PM
I have not played with the large leds, but whenever I built little led circuts, for rcs or flashlights, I simply used a resistor to limit battery current. Leds cause a voltage drop across them ( being diodes.) I simply calc'd the batt voltage minus the drop voltage (3-4v iirc for little white leds) then choose a resistor that would provide 20ma at that voltage. More stable the output voltage, more consistent the brightness. Best results were running off a ubec.
Idk so much about the big led. You have to calc the needed wattage of resistor as well. You may just need a small one to run that right off the batt, however I'd have to see more specs and sit down and work it out.
For all the hassle Id prolly just buy the proper driver for such a large and pricely led. I also tested mine on a breadboard first to test my thinking and design.
