zeropointbug
Z-Pinch racer
zeropointbug's Avatar
02.22.2010, 01:18 AM
Scorpion answered this problem with their press fit endbell bearing. On the large end of the motor, by the mount.
Three bearings to support the diff/endbell. A large bearing on the mount side, one at the center to the shaft, then the last bearing would support the end of the diff.
Oh, that sounds good. But what is the second bearing supporting? Doesn't make sense putting a bearing in the middle if it's to support the rotor? Am I missing something?
