el tomaso
02.22.2010, 03:29 AM
Thanks for the replies, guys.
I am going for the MMP anyway, its the motor I'm not sure about. I have run the castle/neu 2650kv of it on 4s, without heat problems. If it can do that then I have faith it will pull a >1900kv motor on 5-6s even better.
I have been thinking, if Mike doesn't have a medusa 1600kv either, I could afford a tekin. Maybe a 1400kv buggy motor, which would be nice with the sensor esc. Only thing is these rotor things I've been hearing about, but the medusa have the endbell coming off and is also wide open with all the venting
If I am going for a tekin I'll just buy the motor mount, and save the novak mount for that day when I want to find out if old novak HV 6,5t motor still works
I saw the cirtix motor has bolts on the outside, so it wont fit the mount. Its probably not the best motor anyway...
TG
