Ryu James
Ryu James's Avatar
02.22.2010, 08:51 PM
Originally Posted by Chadworkz View Post
I know this is a little bit old, but I just wanted to mention that the method Matrix uses to build their CF kick-up chassis is just as strong as a regular sheet of CF. They use a bonding agent that is stronger than the CF itself, and the aluminum inserts are just plain awesome...they keep the droop screws from digging into the CF causing rough holes, and help in other areas where parts will me moved around a lot, such as the motor-mount etc..
Anyway, Ryu, awesome build and work on your CF chassis, and everything else you did...excellent job! I work with CF quite often, and know its pitfalls and benefits, and even know, or have discovered, quite a few tips and tricks to use when working with it.
I am actually getting ready to start building my own custom brushless CF E-Maxx Truggy (LCG) Chassis (with kick-up) and custom brushless CF Revo Truggy (LCG) Chassis (with front kick-up & rear kick-down), so keep an eye out for those threads.
Hey Chad,
thanks for the post. i had no idea that much work went into the matrix chassis'. they sound like they are very solid and i have only heard good things about them. i havent worked with carbon for a while now but only because i havent been doing any builds. i have held off RC spending for $ reasons for the time being but i have my sights set on my next project and i will be doing lots of carbon work on it. i plan to convert the new 1/5 MCD RaceRunner V4 that just came out. i am waiting for the ultimate version to come out though which is due this fall. the chassis on the MCD is flat and caster is achieved through the gearbox parts instead of bending the chassis. so it will be a perfect candidate for a carbon chassis that wont require any bending. for those of you who havent seen the V4 yet you got to check it out. they have stretched it to the same length as the Baja 5B now but of course it has 4wd. should be sick!
anyway, Chad, if you are willing to share i would love to hear what things you do to work with carbon. have you found a good way to CNC it? if you dont want to post PM me at least. i have done a lot of stuff with carbon but have yet to perfect the process. the last time i had it on the CNC i was still running into issues of fraying etc. any tips you can give would be much appreciated. thanks.
Jammin SCRT10 Neu 1512 1y
