02.23.2010, 01:10 PM
FYI: Mike is making 17mm adaptors for this while he makes the conversion for me. I personally would not want to drill the stub axle to fit the 3mm pin since it could introduce a weak point, but might be ok as this isn't a heavy vehicle.
I have some AK truggy premount wheels/tires I want to try on this when I get it. They are a little narrower than typical truggy tires, but wider than buggy tires; somewhere in between. But because of the larger diameter, it will depend on what Mike comes up with for the gear system for how low I can gear down though. Buggy tires look sweet, but I wonder if truggy tires would simply be too big. We'll see...
