MMP disabling the BEC
Shark413
Shark413's Avatar
MMP disabling the BEC - 02.23.2010, 06:20 PM
I want to run an external BEC with my MMP and I just want to verify that I can disable the onboard BEC by removing the middle wire same as the MM? I am running a JR Z9100s servo which can pull a lot of volts and I hear it can put a strain on the onboard BEC causing momentary shutdowns.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
