RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.24.2010, 11:51 AM
Hardly strange. The slipperential is small so it can fit the majority of setups with shimming. The cd mount is large to fit with standard diffs.
Mike clearly states that the mount requires some mods for most setups and is not for novices. Just drill another hole in top plate or add shims to both bearings.
Exactly. Smaller diffs like the Slipperential need shimming. I may modify the front mount on the next batch for easier use(I have an idea to make fitting various diff sizes much easier), but the product as it is was meant to be "universal fit" - it doesn't fit any diff specifically, but should allow most every diff with proper shimming. I would suggest shiming both sides of the diff - about 1.5-2mm per side should center it up nicely. If you drill a new top plate hole, the mounting template would be null and void. :)
